Disables the source IP lockdown feature on one or more ports.
all | Specifies all ports for which source IP lockdown should be disabled. |
ports | Specifies one or more ports for which source IP lockdown should be disabled. |
By default, source IP lockdown is disabled on the switch.
To display the source IP lockdown configuration on the switch, use the following command:
show ip-security source-ip-lockdownThe following command disables source IP lockdown on ports 1:1 and 1:4:
disable ip-security source-ip-lockdown ports 1:1, 1:4
This command was first available in ExtremeXOS 11.6.
